In a fuel (petrol) fire it is a very rapid fire in which the vapour is ignited, the heat then turns remaining fuel into vapour and this burns and is basically a small explosion as opposed to a fire.
If you ignite diesel its actually the diesel and not the vapour which burns which is why its atomised through diesel injectors in an engine, it burns much more slowly and more thoroughly.
With the battery packs you get issues, with Li-On cells they are prone to self combustion and this is through heat damage or a pack not particularly well constructed, if one cell overheats it can self combust and if any part is ruptured it can burn as well as damage the surrounding cells to the point they rupture and spontaneously combust and this is a major issue with battery vehicles as they combust and don't need oxygen or anything else; race cars are in open air and have lots of oxygen and to stop combustion you remove the fuel or oxygen, or cool it down to the point it won't combust. For traditional fuels you only need remove the fuel or oxygen and heat then the fires out, and various types of fire extinguisher exist and each has its own positives and negatives.
In a lithium cell fire you cannot extinguish it without some very specialised and expensive equipment so once they combust thats it, put water on them and it accelerates the combustion and makes it worse. Lithium ion cells are built on giid matrices and this is how they connect individual cells together to make a block, they then connect numerous blocks together to make a complete battery pack; currently they are looking at altering the grid matrices from plain strap to tubular matrices so they can pump coolant through them and a radiator to prevent individual cell overheating during rapid charging and discharging cycles to prevent overheating and spontaneous combustion, and this is why I raised the issue.
In an F1 car they use hybrid technologies and lithium ion cells and this is why I raised the point, we know his car was torn in half so did this damage the cells, and did the heat from the fire damage his cells?
If you look on You Tube they have actual videos of electric car self combustion and on Top Gear there is a video of Richard Hammond losing control of an electric car and this going off the cliff, he walked away but the electric car self combusted.
Why "follow" anyone? And while I believe LH is the best driver in F1 by a big margin at the moment, Grosjean, who was the luckiest driver in F1 by an equally big margin, is also the worst. So why follow him?I always follow Hamilton, Russell, Albon and Grosjean. Lando not so much.
Hamilton came from working class background, Lando's father is one of the richest men in the UK. Albon's mum, fraud. I don't know about Russell.
I don't care what they do off the track. I never watch any of the race preamble. I start watching at 9 minutes past 2, stop when they cross the finish line.
Much much worse than a hundreds of degrees fire - must be bad then...
most of the rubber seals are pretty high tech. After an intense fire they leave HF residue. Everyone can see the fire and usually takes precautions. Can’t see HF, so when you touch contaminated parts sometime after the fire It’s eats through your flesh and keeps going. HF has an affinity for the calcium in bone. Not a pretty way to loose part of your body
Agree, and understand - but worse than a fire? I think not.
And in the field of vehicle recovery after vehicles have been burned in accidents, or after thefts, particularly in the 90's.
Burns without a flame but a bucket of water kills it instantly.
Without being disrespectful it's the best track to take over the fastest car as it's got fewer places for mistakes...but easy to leave a tenth or so on the table and loose 10 places.Quick isn’t he? Interesting to see how he gets on in 2nd practice etc
Little interview with George.
https://www.skysports.com/f1/news/3...4ZONW1QO5oBVV7l_wE1bUAJPza9fiaIWpoWvQ8CdDihKc
