monkeymark
Does anyone know what the connection is on forklift gas bottles?
Bingo! Thanks.Try googling for a forklift bottle coupling instead of a connection.
keep it upside down then and it will beFork lift bottles are liquid take off, instead of normal vapour, if the OP monkey mark tells us what he's up to we might be able to avoid part of county Durham being wiped off the map.![]()
i have one on a stand for filling smaller bottles with
Darlington could only be improved by a large propane disaster though
.Dunno what it's called, but it should have a long, bent syphon pipe on the inner end so that the evaporator can pick up liquid from the lowest portion of the cylinder rather than gas from the top
look at posting timeFork lift cylinders have a big arrow pointing down telling you which way to mount them so you get a liquid gas feed,
Its called a dip tube if you look at the bottom of the cylinder when on the fork lift there should be a large white arrow that points down that is to indicate the direction of the dip tube. oh look utube has a dip tube vid
To clear things up a little.Fork lift bottles are liquid take off, instead of normal vapour, if the OP monkey mark tells us what he's up to we might be able to avoid part of county Durham being wiped off the map.![]()
What have you got against Twickenham ?
