Yep, and bongs a warning too if it is like my Audi (I think you can turn off the bong with DCS but I have not bothered to )My VAG still does this!
^^ Those are They. I can't recall any of my older cars having anywhere to plug them in though (apart from the Land/Range-rovers).
Does your Audi sound the piercing siren of doom when you enter the fuel reserve? And then every time the ignition is turned on until you fill up?Yep, and bongs a warning too if it is like my Audi (I think you can turn off the bong with DCS but I have not bothered to )
That's an image from the web.
They would clip over the window and be plugged into a socket.
My Old Man had a AA Book Of The Road, they get a mention in it.
Part of this is a penalty of automatic lights - unfortunately the sensor thinks its light enough to not need lights and sadly the automatic sensor has replaced the common sense part of most drivers
You're having waaaay too much of that stuff...........![]()
And am I alone in having dash lights/display which can be dimmed using a rheostat thumb wheel?
I'm astonished at the number of vehicles in poor visibility with DRLs like searchlights, the drivers of which either don't realise, nor care, that they have no lights on the rear.![]()
Since most of the rest of the world is unlit, slowing down to match those conditions, and not relying on the lighting arrangements of oncoming cars to set one's speed by, is the way to go. I have to remind myself that this is how it should be.
Yer, but it is not that loud non of the warnings are, it would be better if ABS fault or low flud levels shouted louder than the lights are left on.Does your Audi sound the piercing siren of doom when you enter the fuel reserve? And then every time the ignition is turned on until you fill up?
Wish the Passat was like that; utterly terrifying when it goes off.Yer, but it is not that loud non of the warnings are, it would be better if ABS fault or low flud levels shouted louder than the lights are left on.
I remember those too, and the matches were to stick the bare wires into the top of the battery posts.View attachment 94050
Quite possible and I would offer to try, but for the 400 mile each way drive.Vagcom might be able to disable / lower the volume?
