Rusty
It is easier to ' blow holes ' when butt welding two pieces together , you might have to adjust wire speed / power settings slightly to suit.
Tack weld the two plates together starting with one tack at each end then one in the middle then one every 25MM or so , finally join tacks together ( in short spurts to minimize distortion or go for it and weld in a single run and be prepared to do a little ' panel beating ' work on the weld
