ghostdancing
- italy
finally i was able to try the first tig ever in my life..i used the pedal; setting: the up\down slope to minimum (10A), pregas 0,5 sec, postgas 5 sec, 1,6mm tungsten, 7liter\sec gasflow, material is 3mm mild steel flat
current setting: the display doesnt show the amp..i turned the the amp knob but it reads 10A all the time.. so i sat it midway (around 100A)...is this a problem of the machine? the pedal itself has a potentiometer knob: i sat it at max
i made some runs with no filler until i had some flashes, so probably my cheap helmet (it works no problem with stick welding since years) is not good for tig.. so i quit for today
