Don't worry, you'll get the hang of it Dave!opps, that's bad of me. I should have recommended the Clarke one!
Did you used to work at Tallent engineering? the press shop manager, Paul Kent, had a million parts in rework when he came down from there to destroy our press shopI used to use these a lot at work, we called them 'hand linishers'; I found them great. They were air operated but I expect electric is ok for DIY use if you're careful
colour?I have an electric one - very useful and effective when you have an application for it - I have however not had many of those. Can't remember the make of mine, but it has an in line motor and most certainly not top of the range.
A new arm with front roller is only 12 quid from ebay. I replaced mine recently as it had worn the pin hole oval!I've the black and decker one. Very good for reducing my crap welding to a decent finish. The front wheel has worn, and the bearing needs a shot of oil every now and then but invaluable.
Nope! No talent hereDid you used to work at Tallent engineering?
Don't buy a black and decker or any of them with the side mounted motor, It just gets in the way
