BrokenBiker
- Newport, South Wales
put a sling swivel on the escort semi auto earlier, except I didn't think things through. instead of taking the butt pad off and looking inside I just whacked a 4mm drill into it, hit a moulded fin that runs the length of the stock, drill wandered badly, ended up with an oversize hole that wont accept the stud.
I then did it properly, started with a 1mm pilot that ran into the rib then a 3mm hole and wound the stud in, plenty strong enough for what I need.
now I have a hole in the stock that is likely to let moisture and dirt into the hollow stock, there is a nut in there that holds the stock onto the action so want to seal it back up to stop rust.
I was thinking just melt a bit of black plastic onto a bit of tin foil then pack it into the hole while its still hot enough, file back to shape afterwards?
anyone got any better ideas? don't really want to use silicone, too messy.
the wall thickness of the stock is 2mm, assuming its abs, looks moulded
