Hi got a few questions and thought id pop some pics up to give you a better idea.
When fitting tha new front panel, what should i be doing with the new panel regarding the prep. Should i take of the original covering that came with it or will the etch primer go on top? what about the back of the panel what should i be using to coat that with?
Also where the upper and lower panels spot weld where drilled off there is some surface rust. after giving this a quick going over with the wire wheel what should i cover this with before welding the new panel on?
And the last
the rear panel has a few spots of surface rust, which will be wire wheeled. This panel will be covered with sound deadening, so will a spot of zinc 182 be ok to cover the spot where the rust was?
Thanks in advance
And the last
Thanks in advance
