123hotchef
- Kent
Any way whats the best way to check the garden is level when i start moving the mud about,
that stinks worseJeyes fluid,![]()
a cheap set of water levels from screwfix and wooden pegs and a 12 foot scaffold plank or a long steel pipe or tubeAny way whats the best way to check the garden is level when i start moving the mud about,
good idea whats the pipe for? I have a coupe of 12 foot scafie polesa cheap set of water levels from screwfix and wooden pegs and a 12 foot scaffold plank or a long steel pipe or tube
Poppycockthat stinks worse![]()
ideal. u lay them down a distance a part at right level then fill in between with your hardcore or whatever and thats your levelgood idea whats the pipe for? I have a coupe of 12 foot scafie poles
ah i see thanksideal. u lay them down a distance a part at right level then fill in between with your hardcore or whatever and thats your level
the mrs is sick of the mud in the house also, once this is done thats it gardeing will be a thing of the past for me I HATE gardening!I’m counting how long before you have pallets of proper turf delivered and are barrowing it back in! Hideous stuff fake grass.
We have many dogs here, two of our own and each holiday cottage usually has either one or two as we are on the pet friendly list. Clean up after them and they are no problem.
. . . Now geese, that’s another issue.
can I not just use some hose pipe filled with water then why the need for the fancy bits on the end of the screwfix jobbie, I can use what I have here to do the same job.ideal. u lay them down a distance a part at right level then fill in between with your hardcore or whatever and thats your level
not realy the ones u buy have caps on to hold the water while you move them aroundcan I not just use some hose pipe filled with water then why the need for the fancy bits on the end of the screwfix jobbie, I can use what I have here to do the same job.
Or who!!I do think dogs are worse than bitches. I’ve only one dog at the moment and he is only allowed to use one of our lawns as a toilet. It’s pretty yellow but never was a good looking lawn. Our house is built on the old town dump, god knows what’s buried under it.
the review on them are soooo badnot realy the ones u buy have caps on to hold the water while you move them around
