Fabricate Repair Piece?
  1. keefbeef New Member
    14
    Ballymena
    Not ebay, breaker in Newry. Wasn't much, so not too worried but it being an expensive piece of scrap.
  2. Melvyn Best Member
    457
    Cambridge
    Welded suspension components are an instant MOT failure
  3. Dcal
    Dcal Forum Supporter
    2,134
    Antrim Northern Ireland
    An awful lot of suspension components come welded.
    james butler and Morrisman like this.
  4. Ton-up
    Ton-up Member
    1,593
    Essex, England.
    If they are cast or forged, yes, but this is a fabricated subframe according to the OP.
    stuvy likes this.
  5. Morrisman
    Morrisman Forum Supporter
    2,336
    Staffordshire, England
    As an aside, out walking the dog today and noticed a chap has three Triumph Spitfire chassis laying in his drive way, chained together. And a scruffy dirty looking glassless car with a fast back on, and a roll cage inside.
    So if this subframe is off a Spitty, I know a man who probably can. :D
  6. keefbeef New Member
    14
    Ballymena
    Yes, this cup was welded to a much larger frame made up of different welded sections. Agree that you can't weld a casted piece.
  7. Dcal
    2,134
    See below
    In my opinion if it isn't an excellent, ideally invisible, repair I wouldn't bother.
    As an aside a mate has a old focus estate that failed it's MOT because of corrosion to the front cross-member.
    The tester went out of his way to batter a hole in it and he told him not to get it welded.
    My mate didn't tell me until after he had a second hand one fitted.
    I was gutted because I would have welded it and let the tester fail it, then appealed his decision for a bit of fun.
    He only keeps it as he bought it new and doesn't really need it so we could take the time to mess.
    6 Highly stressed components
    The severity of corrosion in highly stressed components, such as steering and suspension arms, rods and levers, can be assessed by lightly tapping or scraping with the corrosion assessment tool.
    In places that can't be reached by the corrosion assessment tool, an alternative blunt instrument may be used.
    A highly stressed component should be rejected if corrosion has resulted in serious reduction in the overall thickness of the material or has caused a hole or split.
    Welded repairs to highly stressed components aren't normally acceptable, other than where the component is made up of sections that are welded together. To pass, the repair should appear to be as strong as the original design.
    Morrisman likes this.
  8. colnerov
    colnerov Member
    3,501
    Nr Gatwick UK
    Hi, The MOT tester manual says (section 2.2) a reason for failure would be for 'inappropriate modification or repair or use of excessive heat by welding to steering or suspension components'. That's very subjective and open to interpretation.
    Colin
    Dcal likes this.
  9. jordan1 Member
    2,054
    Yorkshire England
    If the rest of the vehicle is sound [unlikely] then persevere with it if that's what you really want, otherwise scrap it and get a better project car, plenty around cheap.
Advertisements
