chrisg3103
the time has come for me t change my blade, thing just makes a lot of noise and sparks now. i made a half arsed attempt at grinding down the guide teeth so the carbide teeth would be exposed again but it just didnt really work
so bought a cheap 230mm steel blade from fleebay, didnt realise the saw was 255mm
also goes on the saw back to front
but it dosnt cut all the way through
(being 20mm too small)
edge on the right was butted up against the back of the saw.
so looks like ill have to space everything out about 30mm to get a clean cut and probably use the slide which it says not to do for some reason when cutting steel.
BUT can anyone anywere find a 250mm (10') steel blade in the uk!? the only ones i found are in america.
i quite like this saw but this is fast putting me off it, its like they are trying to force you into buying the multi purpose one for the mitre saw.
getting a nice big donky saw chugging away in the corner is looking appealing....
