JonnyAlpha
Hi;
I'm sure I have asked this before but cannot for the life of me find my post.
Can someone offer some advice on the minimum timings between the following:
1. Epoxy Primer (Joton Jotamastic 87).
2. Seam Sealer(Ever Build Tecnic Pura Flex http://www.everbuild-tecnic.co.uk/product/puraflex-40/ )
3. U-POL Gravitex.
4. Cellulose Top Coat.
I was going to lay another coat of Epoxy over the Seam Sealer but was advised that this was not required.
Found the Technical Data which says Cure Time 3.5mm 24Hours, it also says Paintability - Water Based (yes) Solvent Based (Trial Necessary), so looks like I need to let it dry for 24 Hours before attempting to chuck Gravitex over it, especially with Cellulose Thinner :-(
Maybe I should brush paint some Epoxy over it?
This stuff was recommended to me for Auto use so I thought it would be fine?
3. U-POL Gravitex.
