Smallfry
HE's Spartacus.
- Kent UK
As title. making an adaptor plate to couple the wrong gearbox, to a wrong engine. I see most commercially available ones are made of alloy, and are usually quite thick, but apart from the weight, whats wrong with steel ? It is a LOT cheaper, and more readily available.
Any reasons NOT to use it ? Engine block is iron, and gearbox is alloy, as are a lot of OE fitments
Difference between the two units is about 100mm diameter, so about 50mm each side, so if made from steel, how thick ?
Is 6mm thick enough, so as not to distort, or would thicker be better, 8 or 10mm ?
I need to make up 35mm thickness in total, but at least 25mm needs to be a "simple" spacer, rather than an adaptor, which I could make up from segments if necessary.
