daleyd
- Wrexham, North Wales
Yeah I understand that “wasted” heat from lighting is contributing something, my point is that it’s doing little of any use (in most cases). I don’t think it would ever translate into 1 kw less heating input needed as it’s not warming an area where you need it. I can imagine it making a small difference but I think it would be marginal at best.I agree it's a low hanging fruit, so why not go for it. Just have to keep in mind that it's a rather small fruit, in the bigger picture!
If your waste heat from lighting is 1kW, if it's within the heated envelope of the house, that's 1kW less heating needed. And, is more than likely lower carbon than a gas boiler's 1kW.
Utterly pointless when you want the house cooler or for outdoor lighting though!
I'm not against LEDs, all but a few random rarely used bulbs here are LED.
The ceiling area is already warm air that has risen from radiators or other heat sources, waste heat from a bulb is simply heating air that is already warm and at a level that no one notices - the air is already at ceiling level. If you were to put 1kw of ceiling lighting on and no other heating source or a 1 kw fan heater at floor level then I bet you would feel warmer with the fan heater.
. Maybe that’s where the real energy savings are to be made.
Normal usage is 8p.
