Screwdriver
I am also in the throws of building an electrolysis cleaning tank and need a few questions answered. I am using a domestic 50 gallon water tank and lid.
I would be very grateful for any help on the following questions. Tinternet takes me around in circles.
1. Voltage, is there any benefit in increasing the voltage on a larger tank ie 12-24v?
2. Power source, apparently needs to be better supply than a PSU can manage. Is a battery charger suitable in the long term?
3. Sacrificial anode, is there a rule of thumb on sizing these or do you just hang a few lumps of steel in there? Is sheet steel better than bar or big rounds?
4. Dilution rates of the soda crystals, is there an optimum ?
Sorry for the hijack but not worth starting another thread for.
Bob
1. Increasing the voltage will increase the current flowing (amps) 1-2 amps is all you really need. More voltage works more quickly but can damage delicate parts.
2. Anything will do so long as you are confident it can supply power (say 1-2 amps) continuously without supervision and without bursting into flames.
3. Anode works best "line of sight" so you ideally want to surround the workpiece. Anything that can't "see" the anode will be reduced less efficiently (you might not notice on an overnight stew)
4. Any amount that allows 1-2 amps to flow. More electrolyte = more current, more sacrificial anode material also increases the effect as does more volts. Find a balance, 1-2 cupfulls for a big bucket is plenty.
I chose Daz because if you read the packet it contains a high proportion of sodium carbonate, you could just use sodium carbonate powder but I find the soaps can also help the process (I might be wrong about that). Don't use stainless steel for the anode, it will produce toxic waste. The process gives off hydrogen, don't leave it in a sealed room.
