when using low hydrogen rods or any rod for that matter, do you have to use an oven to preheat them? can you get away with just using them stright from the packet? just a courius question
what will happen if you dont use one?
even better a Lorch Inverter running hot start technology (you can leave that with me if you like Matt)
Haud on there. If the rods are straight out of the unbroken packet, you're fine, just weld away. Otherwise, as stated, dry - but according to the instructions on the packet.
Some rods you don't need to worry about at all, eg 6010, 6011's. But they can crack easily if you don't put a hot pass in to drive out the hydrogen.
6013's can perform well as long as they are not damp.
ZZR - How can 60xx rods become as strong as 70xx rods?, the 60-70-also 80 code denotes strength.
Also, a 7016/8 is a sod to use if not properly dried, regardless of the weld properties.
And, Brendan, you're not putting the rods in the oven to preheat them, but to dry the flux. A warm rod will often give a better strike though.
I have some Lincoln and WeldIt 7014 rods. They look and work the same as 7018's (with low to medium penetration.) Nowhere on the package do they specify they need to be kept dry. sounds like a good alternative especially if you use a deep penetration rod for a root.
Those reflector bulbs chuck out loads of heat, we've got a giant lava lamp that uses a 100A one to heat the liquid, it get's bloody hot!
A's and W's can be confuzzleing![]()
Hehe, it's cos we're always talking about welders in terms of amps
Not much use in me editing my post now seeing as you've quoted me but I will anyway![]()
