My outside sockets are on seperate MCBs so they can be isolated when not in use.
Always a good idea.
the inrush current on a 110 transformer is very high and is a regular occurrence switching them on and offyou could still spur off the ring main just use an FCU. I would say if your 110v transformer is triping a 32a MCB it needs looking at.
the inrush current on a 110 transformer is very high and is a regular occurrence switching them on and offI see it all the time with builders plugging in to punters houses
do u mean mcb . rcd is earth leakageMy big 110 transformer ended up with a 16a plug and only being used on an old genny as it tripped every rcd every time it was plugged into a 13a socket
Then batteries improved so I scrapped it and bought mostly 18v tools
Its highly unusual to use a type D in a domestic situation due to the disconnection times and earthing requirements.Good morning gents.
There is also 'D' curve breakers!![]()
No problem it wasn't meant as negative comment.Good morning workshopchris.
It wasn't meant as a recommendation just as a retorical option!![]()
