madkayaker
Pro sparkey Pro Welder
and be carefull when your puliing those fuses out that there is no fuse wire pokeing out over the to and there very slippery and will brake if you drop them
look where the electricity boards supply comes on to the premises there will be a 3 phase cutout. in laymans terms 3 large supply fuses then within 6inch will be either a 3 phase meter or 3 old type single phase meters and from them in to an isolator and in to a 3 phase db . as said your other supply is a sub mains supplyhmmm thats different, it used to be a whole complex with multiple units owned by one company. Like i was saying there is another fuse box and meter at the back of the workshop. Its one single meter and looks a more modern unit however it only spins when using certain parts of the workshop and does not appear to link anywhere near the other meters.
With the setup i have does this mean i have a supply thats branched off from a supply that not located in the workshop. This may get confusing.
thanks for the help madkayaker, how will i know how many amps my supply is getting. Is this a job for an electrician or would there be any markings or rating on fuses etc.
Ask the power company. You might have to chase about a bit on the phone before you get someone technical with that knowledge. Now there's been de-regulation it may be that the people you pay your bill to aren't the ones who own the equipment and who will know these things. Maybe not in Scotland though if it's Scottish Power and always has been.
The fuse rating of the main fuses won't be exactly the amount of power you are receiving. They'll obviously be rated higher than that, otherwise they could be blowing regularly. I have 4 main fuses (there's one for the neutral too) and they are rated 100 amps each. The power company told me I have 80 amps per phase incoming.
