Morning chaps!
I've got a van with a roof rack ive made from 4040 aluminium extrusion, and just got a brand new second hand awning for it. Mounting to the roof rack is going to require custom brackets, so just looking at whats the easiest route is going to be.
Theres a company which produces these brackets (in the states) which would be ideal. Obviously they are horrifically expensive for what they are, but its basically what im after.
measurements needed are roughly 120mm x 60mm ish, 120mm wide. Probably looking at 5-6mm thick mild steel. I was hoping that places like metals4u would have a big range of mild steel T section that i could literally buy a couple of peices of pre cut to length and just drill some holes. However the largest T section i can find is 50x50mm.
Choice of aluminium T section however is much more vast but im concerned about strength as the awing probably weighs 20-25kg and if a bracket snapped on the motorway it would be catastrophic...
Is this concern justified do you think?
What other options are there for making these with no welder available? Im currently looking to see if maybe cutting a bit of RSJ up would be possible
