ChrisJ
I wanted to replace the earth clamp on my 160 amp arc welder, so I oredered a new clamp, and was puzzled as to how he cable connected to the new clamp, basically on the old clamp the cable fed through the hole in the handle end of the clamp and was secured under the "U" shaped part of the inner jaw, it has always been this way since I inherited it off my Dad, anyway it turns out the original clamp is for a much higher rated arc welder (400 amp) and I need a cable lug fitted to the end of the 16mm earth cable, to connect to the threaded bolt on the top of the new clamp, which seems to have a 6mm bolt to attach the lug too, can anyone show me what type of lug I need and how to fit one please?
have attached pictures, and thank you
Chris.
have attached pictures, and thank youChris.
Just popped down to the local Motor Factor I use, for the lug we even went out the back and used there vice to squish it on, wet myself when they said 50p for the lug and £14 labor, glad i popped out now needed a bit of a chuckle, and thanks for all the responses guys you never let me down
