intransit_89 Member Messages 86 Jun 29, 2008 #1 hello i have a clarke pro 90 and when i finshed the welding yesterday the earch clamp was warm it burned my hand nerly ??
Hitch Moderator Staff member Messages 13,579 Location England Jun 29, 2008 #2 A bad connection to what you were welding probably, is it a spring type, with a very loose spring perhaps?
shenion Tool Pack Rat Messages 7,586 Location Stone Mountain, GA USA Jun 29, 2008 #3 Bad connection. Eithe rthe metal you clamped it to was not clean or the cable is loose. On my 130, the bolt the cable was connected to was not very tight.
intransit_89 Member Messages 86 Jun 29, 2008 #4 its a spring type you usly have to put something under it to make it clamp can you get new clamps then? is it just the clamp or do you get the wire as well?
shenion Tool Pack Rat Messages 7,586 Location Stone Mountain, GA USA Jun 29, 2008 #5 You can get better clamps. The Clarke one is ok, but the clamping force is weak. I like the Lenco style claps. They are solid bronze/brass with a real strong clamping force. I have 2, one actual Lenco and a Chinese clone. Bothe work great. I got them off ebay.
Hitch Moderator Staff member Messages 13,579 Location England Jun 29, 2008 #6 Just cut the old one off, strip the cable back, and put the new one on. Some you might need a heavy duty ring terminal to crimp onto the cable. A few quid should sort you out a reasonable one.
intransit_89 Member Messages 86 Jun 29, 2008 #7 ok thanks for advice will get a other one then maybe why when i try to weld it dont sound like bacon frieing 30% its more of 70% of humming noise! mosly so could al be to the earth clamp then thanks for the info
sharkey Just this guy, y'know. Messages 26 Jun 30, 2008 #8 Warm is okay, but "almost burnt my hand" is HOT. I'd agree with the other replies, if the clamp is a cheap sheet-metal construction, replace it with a proper one, you'll get a much better connection. The other thing to remember is to make sure the metal where you're clamping is nice and clean, hit it with a flap disc if necessary. -----sharks
shenion Tool Pack Rat Messages 7,586 Location Stone Mountain, GA USA Jun 30, 2008 #9 Here's the Lenco style clamps I have. They work well: It is a 300A clamp. Almost takes 2 hands to compress spring to open more than 1" They werk well.
B bronze Member Messages 10 Jul 2, 2008 #10 Why don't anyone use screw clamps? I find them to the overall best choice. Picture included: http://www.weldingtorchparts.co.uk/...rew_down_earth_clamp_-_m[ekm]100x100[ekm].jpg
