S sini83 New Member Messages 2 Location Croatia Dec 2, 2019 #1 Hi, I bought zx7-200 welder. Where do I connect earth wire ? Cables are 16mm2 and 1.5m length each, is this enough thicknes for 2.5-3.2mm sticks?
Lewis_RX8 Member Messages 1,574 Location Scotland Dec 2, 2019 #2 Is that made for American 2 pin sockets and plugs?
Shoggi Member Messages 238 Location Bradford west yorkshire Dec 3, 2019 #3 Definitely looks like it's for a 2 pin plug I recently bought a concrete poker that was 2 pin but it works ok on uk plug not sure if the welder will be ok due to power ,,
rikrobson Member Messages 3,963 Location Perth, Scotland Dec 3, 2019 #4 do you meant the welding cables? the first picture shows the position. the welding electrode goes to the - and the ground return (do you mean earth) to the + 16mm2 should be fine for the welding cables. I doubt the unit has a high duty cycle if you are on about the mains cable. the unit is not earthed from the look of the photos. you could replace the mains cable with a 3 core and run the earth wire to the case
K knighty Member Messages 3,392 Location Sunderland Dec 3, 2019 #5 rikrobson said: the welding electrode goes to the - and the ground return (do you mean earth) to the + Click to expand... erm... that's backwards?
rikrobson Member Messages 3,963 Location Perth, Scotland Dec 3, 2019 #6 Flop, Too much thinking about TIG. but 6013 will run DCEN or DCEP.
S sini83 New Member Messages 2 Location Croatia Dec 5, 2019 #7 rikrobson said: 16mm2 should be fine you could replace the mains cable with a 3 core and run the earth wire to the case Click to expand... Thank you
