Anyone use Aspen fuel? I've bought some for the small engined things but haven't used it yet.
I use Aspen 2 because I 'acquired' some... It's good stuff. Not tried Aspen 4 yet, probably won't either as it's expensive compared with unleaded.Anyone use Aspen fuel? I've bought some for the small engined things but haven't used it yet.
The carbon footprint of biofuels, is terrible.You get lower mpg from ethanol so you’re not going to be any better off financially. The only benefits are environmental. The ethanol portion of the fuel has a lower carbon footprint than petrol.
The ethanol production uses more diesel and other conventional fuel energy than it produces.
It is a "Symbolic" effort to fix something.
Doesn't say that HPtuners is rather expensive to right software with and needs to be licenced per vehicle !Apparently my Ampera/Volt has the maps in the ECU to run on E85 but GM decided to not enable them when it went to market:
https://www.fuelfreedom.org/john-brackett-made-a-chevy-volt-run-on-e85-and-it-was-easy/
