octo0072000
- south yorks
DMF clutch centre is solid no springs the DMF is the springs
solid flywheel clutch centre has springs
Sure my DMF Astra clutch had springs when I changed it.
Dark now but will look in the scrap pile tomorrow.
So I checked today.
It sort of has springs in the clutch plate. Not as big or as many as in a standard plate & they seem to be in a plastic enclosure.
Over the passed 3 years I have weldedup 5 DMFS a transit for a m8.. its still ok 2 years on..a volvo v70 d5 my own still ok. a vauxhall astra deisel 1.9 150 bhp still ook 40000 miles later.. DMFS ARE JUST CRAP WHOEVER INVENTED THEM SHOULD BE WHIPPED!!Hello all,
looking for some advice. The Mrs car C-Max tdci needs a new flywheel. The dual mass one is slowly becoming more than dual. Have seen the kit for it around £400 (Sachs) but motor factors quoted £500 (unknown) for kit - oh and what are LUK like as a product/brand? Back to point - have been told that the conversion from dual to single mass flywheel causes issues in time e.g. vibrations eventually knacker fuel pump/engine overtime requiring new engine at £1500.
Anyone heard/know about such issues?
Thanks for looking
I've replaced 2 DMF's now for others, both drive like pensioners (they actually are pensioners) and neither of them ever revs above 2k, I've tried telling them they are killing it but they both say "I've been driving diesels for years and this is how you drive them for maximum life & economy" they won't listen when I tell them the diesels of their era and today's are totally different beasts.What kills DMF is driving like a pensioner and short shifting - expressway to wrecking them...better give it the beans 2.5-3K, get some decent revs up, then its got centrifical force to keep it spinning between gearshifts...
Most of them I've heard of going bang are driven "carefully"...no coincedence...
The first one I did the owner can weld, so he stick welded it, I spun it in the lathe at work and it ran true but when fitted back in the car it was awful to drive, fit a new DMF and it was fine.As this is a welding forum I'm surprised nobody has suggested it - weld the 2 halves of the DMF together to make it a solid flywheel, get it balanced if you want and stick it back onto the car. I know a mechanic who does it regularly without a problem!
that will be a bit awkward to get a shoe on175000 miles and counting from my passat tdi 130 (+ !) on the original clutch and dmf, I have a very heavy right foot! Sadly it's just about to get replace by a Nissan Qashqai, it's been a brilliant car
