zx9
- South East London
My Drummond should have a 1MT taper in the spindle but some kind sole has bored it to exactly 3/4 of an inch. It is parallel and approximately two inch deep, there is a further ridge where the diameter decreases untill about 1/4" where it closes up to the original bore.
I guess I have two questions:
Why would anyone open the spindle up to 3/4 of an inch? I believe that it has been done with care as the bore is very cleanly turned, almost polished, it can not be accidental miss use of a boring bar.
And two what should I do about it, ignore it is not really an option because I wanted to be able to turn between centres.
Should I:
A. Try to find a better spindle - Hen's teeth comes to mind.
B. Make another spindle - possible there are drawings on Yahoo but I can not turn between centres remember. I could use the four jaw so it is do-able, if that is the option what steel to use, EN8 or 24?
C. Make a 3/4 x 2" plug to loctite into the old spindle and bore that out to 1MT or 2MT no reason why not go up a taper size. Again what steel to use?
D. Stick a chuck back on it, hide the lathe dogs at the back of a draw and forget there is a problem.
Should I:
