Mick Annick
- Burgundy, France (450 miles SE of Somerset)
Apologies for such basic questions, but it’s over 40 years since I last did any of this.
Need to drill some holes and tap to 10mm x 40mm deep into the end of 25mm solid bar. I drilled 3mm pilot holes first, then tried to enlarge to 6mm, but snapped 3 6mm drills in the process! What am I doing wrong? Drill speed too slow, too fast, wrong angle (I’m having to use a hand held electric drill)?
I eventually managed to get all the bits out and holes enlarged to 8.5mm for tapping, used a taper and then plug tap (1.5 pitch) , cleaned out all the swarf but the bolts don’t want to go all the way home, they screw in OK to about 25mm but then start chewing the thread. I’ve compared them to the taps and they appear identical (mesh with no gaps), I found a couple of old Nuts and bolts in my toolbox which screwed in fine, and the new bolts fit the old nuts OK, so I’m a bit baffled, what am I missing?
