Cato
- Birmingham, UK
I have to drill a couple of holes in a stainless steel box section. It's got to be done in situ unfortunately so that takes a low speed on a pillar drill out. The other issue is that where it is makes coolant/lube exceptionally difficult if not impossible to use. They're only 3.5mm holes (for self-tappers) so I'm thinking decent quality HSS twist bits kept at as low a speed as I can with an 18v battery drill should cope OK?
