rtbcomp
Moderator
- Sheffield UK
Depends.
Can you determine where the wires from the switch and smaller coil go? If the smaller coil ends up being connected across live & neutral via the switch all that will happen if you swap one end from live to neutral is that you'll end up with both ends of the coil connected to neutral.
If on the other hand one end of the start winding is connected to the centre of the main coil what you suggest may work.
