123hotchef
- Kent
so the bolt is still in the hole below the drill bit also?
that could work the drill and retap can u re tap to M8? once its outHow about a 6mm core drill and core out the bit with the broken off drill in it.
There’s a technique on youtube where the guy puts a copper tube down the hole & then introduces mig welder down the hole, wire welds to the drill bit & combination of heat/pulling removes bit. Slightly tricky on such a small bit but might do the trick. RonAif i had a 3mm hss bit with the tip broken off deep in a hole would a carbide bit be able to drill through it?
Better with a stick welder at 2.5cm deep I would.say.There’s a technique on youtube where the guy puts a copper tube down the hole & then introduces mig welder down the hole, wire welds to the drill bit & combination of heat/pulling removes bit. Slightly tricky on such a small bit but might do the trick. RonA
Have you got a link mate?There’s a technique on youtube where the guy puts a copper tube down the hole & then introduces mig welder down the hole, wire welds to the drill bit & combination of heat/pulling removes bit. Slightly tricky on such a small bit but might do the trick. RonA
the bolt is drilled right through bar the last thousandth or so, so itll be 18-20mm below the surface.Just to clarify you have tried to drill out a snapped bolt? If so how far is the bolt below flush now?
Ive not done it but electroysis could work at low currents. First the oxygen created at the anode will react with the aluminium and give an anodised oxide layer. This will increase the resistance which will shift the reaction to oxidise the HSS and eat it.Isn't there some sort of electrolysis process you can use? I'm sure I've heard of this being used. A chap I used to work with had a small set up for his hobby of restoring vintage aircraft.
Anyone know?
