Dr.Al
- Gloucestershire, UK
Can anyone recommend a good low-tack double-sided tape, available in wide widths?
For this sort of application, I currently use 48 mm scotch blue masking tape: one piece on each of the parts to be joined and then superglue on one side and superglue activator on the other. It's a bit of a faff and I get through a hell of a lot of masking tape. I've also read the MSDS of the superglue activator and I suspect it would be better to get through less of it than I currently do!
The double-sided tape I have at the moment has an adhesion strength similar to superglue, so I'd never get stuff apart if I used that.
Ideally, I'd like something with an adhesion strength similar to masking tape on both sides of the tape.
