steviec_lj
Rust Welding Professional
- Barnetby, N.Lincs
Hi guys,
As the garage is still not finished inside, and I'm having a few issues with my back and health again, I have come to ask for a little help.
I didn't want to approach a larger company, as their prices are usually quite inflated for one off jobs, so thought it would be better to pass it on to an individual with a love of metal.
Basically, I am looking to install some door fram protectors and a door protector, in the form of some 2mm stainless which needs to be bent at a 90deg angle to cover the wooden door frame either side of a kennel installed in a garage. I am also looking to install an elongated "U" section across the back (inside) of the door too.
Additionally there is a 4" drain pipe allowing cable access into the garage installed in the corner of the kennel, which will require protecting, so here I am looking at installing a larger version of the door frame protector, with additional lips so that it can be attached to the walls.
I am currently in the process of thinking this one out, but would anyone be interested in quoting for the job? Both supplying and bending? I know its not a huge job, but at the moment I simply don't have the tooling to be bending lengths of sheet.
If pictures/measurements are required, I shall be posting these tomorrow evening.
