bigegg
- Leeds, West Yorkshire
i need to source a domestic door alarm to warn when a domestic external door isnt fully closed:
specs:
will be fitted inside the house.
can be mains powered. no requirement for battery backup.
can be hard wired.
needs audible alarm "beep" approximately as loud as a lorry reversing alarm. this can be either on the door, or wired
at least one visual indicator along the lines of a strobe, or at least a standard 40w bulb (more than little led) which is in a seperate room.
switch controlled to be off/on (so hold push switch in, and alarm doesnt sound so door can be opened for visitors) - accessible from inside house, and next to door.
basically: exmrsegg is deaf, and a bit forgetfull.
she (and others) sometimes leaves the front door not quite closed.
obviously a security issue!
i need something that makes it obvious the door is open: even when she doesnt have hearing aids in.
any suggestions/recommendations.
budget up to £100, but ideally <£50
specs:
can be hard wired.
