rngDeadeye
What wall thickness is the 1" box? If it's 18swg erw and it won't blow holes you have problems! Try the 0.8mm wire on maximum setting and tweak the wire feed up & down while welding.
Now you're just adding problems for the sake of it!What part of Oxfordshire are you in?
Near Banbury...
The weld-through primer was added before the inner wings were screwed to the chassis rails over a year ago...
This is what it looked like at the time
From this:
Don't worry, the red was sand-blasted off, the black stuff sprayed on and the mating face of the chassis rail primed with weld-through.
