- UK
As title. Board in a rental. Passed an EICR around 3 years ago but as the first 3 circuits are not protected by an RCD this would need replacing?
Cheers
Cheers
Spark gap for surges
You might be thinking "why would anyone do that?" looking at the pic, but the rationale at the time was the lighting shouldn't be on the RCD so that the lights stay on if you plug something in to a socket that causes the RCD to trip.
Later versions of the regs balanced sockets and lighting across two RCDs for the same reason until RCBOs became affordable.
back in the split board days I would have put the upstairs lights and downstairs sockets on one RCD and the downstairs lights and upstairs sockets on the other and used a high integrity board with the house alarm and workshop feed on non-RCD.Same, I always thought if you're plugging something in to a socket that trips the RCD, it's better to keep the lights on in the room you're in.As an industrial sparky I wasn't qualified to work on domestic stuff so if I had changed my CUback in the split board days I would have put the upstairs lights and downstairs sockets on one RCD and the downstairs lights and upstairs sockets on the other and used a high integrity board with the house alarm and workshop feed on non-RCD.
This extract from the link is how the issue of the DB came about. There is a trip located upstairs specifically for the bathroom lights. The lights had failed (tenant never reported it) So when we got to the property there was a hunt for a problem which turned out to be the trip in the boiler cupboard. When the power to the property trips/fails, this breaker stays off, which will no doubt end up in a maintainance call. I was going to swap it for a fused spur but then there would be no protection.For chapter and verse on the answer from the experts have a look at https://engx.theiet.org/f/wiring-and-regulations/31678/fail-eicr-because-of-partial-rcd-protection
Don't blame me if by the end you are not any wiser.
My understanding is in a domestic household a plastic CU is still ok but if situated under a stairs, area should be fireboarded out.One important thing is that old plastic consumer units like yours are technically out of date. Modern consumer boards are all metal construction for fire reasons.
Whilst I proactively upgraded my own consumer unit to metal recently, I don't think its required by law in existing domestic properties yet. But a rental property could be a different storey so best to check with someone qualified.
Possibly yeah. The next EICR is due in just over 12 months so I may as well just change the board as said above. New metal board, RCBOs, SPD, up to date for another 5 years.Can't you use a passive (latched) RCD spur?
