JimM
Evening all
I was trying to drill some lat bar earlier this evening and the drill was having none of it. It was a couple of pieces if 8mm tacked together but the drill bit only went in a mm or two and then refused to go any further, tried again a cm further along and it went through no problem. Flipped the piece over tried in the same spot as the first attempt and it went most of the way through before hitting the problem again. It's almost like the steel has a knot in it like you get with wood. Is this a common problem or is it a flaw in the manufacturing.
Cheers
Jim
Cheers
Jim
...Bob
