paulmitchell1984
- Leeds
Hey guys
Recently bought a jasic 200 mig welder now iv not had masses of time to play with it, I managed to weld some 3mm box up nicely but tonight I had some 5mm box to weld to some 10mm plate, managed to weld it ok on a lower temp bit just thought if have a blast at full power on an off cut of the 10mm plate,
There seemed to be little or no control of the wire which I had to have turned right up aswell, eventually after about 3 minutes of playing making the nozzle really flimsy due to heat and then ended up welding the tip up as in burnback took it up the tip.
Now I thi k off hand its .8 wire but can clarify that if needs be.
It's the torch that came with it so not sure what its rated to but I assume it's for lower temps, would bigger torch make any difference to the welding?
Sorry for the long post and hope it makes sense.
