no i tried this 1 hour later it stopped motor burnt out.Could a car windscreen was pump be used? Easy to find 12V motor speed controllers. Bigger than that, the 12V pumps used to pump water in caravans.
That also has the advantage of being instantly available for use on the pillar drill , mill and any other sawing etc . jobs .Just a small pond pump if you must but frankly, a brush and a bit of Rocol or a squirty bottle of white water is more than enough. Spend your time on other things, coolant pumps are only really useful in a production environment, you are going to have it everywhere.
That's why you need 3 separate onesMagnets for brass and aluminium.
