ronan
Found the bearings on Ebay, £7.10 delivered for a pair of SKF ones. The only difference in the part number is that they're ZZ not Z but I assume that means they're double shielded?
Everything else is the same, including the clearance.
Our kitchen is like an appliance repair shop at the mo, I've got the washing machine in bits too, the pressure sensor pipe is clogged causing it to overfill so the whole machine getting a damned good clean and descale.
Thanks for all your replies as always, what a helpful, informative bunch you all are.![]()
You can pick out a seal if you're careful not to scrape anything, i've done it before with bike gearbox bearings.
