hotponyshoes
- Somerset. Uk
I'm sure I've been through this on a car before but can't remember exactly what I did to diagnosis is...
My good lady has a LR D4, she started the car, drove for a couple of mins then had a "charging system fault" message that (apparently) disappeared after a couple of miles.
Completely ignored it and drove home fine.
About an hour later went to go out again and it wouldn't unlock.
I popped home and had a quick look. Battery voltage was right down to 3v and the battery was hot.
I disconnected the battery and went back to work.
Came home about 3hrs later. Battery had self-recovered to about 5v.
Did a bit of poking around this evening.
There are 2 main red cables going to the battery +.
One runs into the main fuse box and the other goes to the starter & alternator.
Separated and probed them. The fuse box one has some continuity to ground but I'd expect that.
The starter/alternator one was zero resistance to ground.
I removed the alternator and the wire was then reading no continuity to ground.
Car did start and drive (only briefly as I needed to move it) with plenty of errors showing!
So, with the alternator on the bench, There is one 8mm stud terminal (B+) and a single-pin small connection.
Putting the meter across the main stud and the alternator case shows zero resistance.
I swapped the probes over and get zero on both ways.
I'm thinking that's not normal and the alternator has a dead short which would have caused the rapid power drain and the hot battery?
However, just to confuse myself, I found another alternator the same (different D4) that I had previously replaced. This one was removed as it had a "charging system fault" permanently on. But that car was running fine for a couple of days in between battery charges. I measured that one and also get very little resistance between the stud and the case?
Anything further I should check before I cough up the cash for a new alternator?
