It will be tight.Great thanks for that, I will have a scrabble under it tomorrow
Keep an eye out tomorrow in the "stuff I've broken" thread!It will be tight.
Nip it up a bit tighter, then it should free off nicely.
Its always used a little bit of water, never been able to see/find anything obvious, the head gasket was "done" before we got it supposedly and always had good result with K-seal so thats what it got!Oh no. Why the k-seal?!
Its often the coolant filler cap if its slight loss. They can often leak from the core plug under the exhaust manifold amongst other places.Its always used a little bit of water, never been able to see/find anything obvious, the head gasket was "done" before we got it supposedly and always had good result with K-seal so thats what it got!
The next tool to be used will be this one if I get anymore issues
Its a real pain on the disco td5's because the heater matrix is quite high up and does not have a bleed point. Even when following the manual to the letter I struggled to get heat through to the interior because of an airlock in the matrix which would not self-clear. Seems that this is a regular occurrance on this engine. Not all cooling systems are the same and the only bleed point is the top hose which requires the heater matrix airlock to go downhill for a considerable distance.My initial response would have been “ take off your sleeve!”
Is one really needed? I’ve re-filled a few radiators in my time but never yet needed a more expensive gadget than a spanner or screwdriver. If the system is subject to an air-lock it will have a bleed at an appropriate point. Cheaper to read the manual (or watch youtube?) than shelling out for an unnecessary and expensive gadget that is not needed - and possibly a compressor, too, for the air supply?
The heaters never been spectacular so perhaps its always had and still has an air lock, will just run it for a bit now and see what happensIts a real pain on the disco td5's because the heater matrix is quite high up and does not have a bleed point. Even when following the manual to the letter I struggled to get heat through to the interior because of an airlock in the matrix which would not self-clear. Seems that this is a regular occurrance on this engine. Not all cooling systems are the same and the only bleed point is the top hose which requires the heater matrix airlock to go downhill for a considerable distance.
The tool was about £20 which I would not consider expensive for the amount of effort saved. Sounds like the OP was successful which is all that really matters.
