Hello. I'm new here. I'm currently restoring an Austin Mini. The body is in very good condition so I don't have too much welding to do. It's about 0.9mm steel. I've been butt welding a few patches in after practising a bit. I'm doing this by cutting the patch to size, tacking it in, and then gradually filling in around the join with spots, eventually overlapping them. It's mainly going well. The only real problem I'm having, is that I am often left with 'dirty' edges around the welds.
It's difficult to describe what I mean and it's not easy to take photos of shiny metal. If anything, the photo makes it look worse than it probably is. In case it's not clear to see, imagine a painted wall, where you have used filler to fill a wide, shallow hole where a plasterboard nail has pushed a piece of plaster out. The filler is been sanded flat and flush with the surrounding surface, but there is a little gap between the filler and the wall surface. That's what I'm getting around my welds. In the gap, it doesn't look like clean, shiny metal (but that may be just because it's in shadow). It looks like there is an outward-facing conical void in the metal, with an inward-facing, ill-fitting conical 'filler' piece of weld in the hole, with a gap that seems to extend towards the point of the cone, but for an unknown depth. I would like this to not happen, so that I can send it flush and have it look like one continuous piece of metal.
I clean off about 5mm of metal around the patch, and I clean all of the patch before putting it in. I also clean the back and make sure there is no paint on it (apart from weld-through primer in some cases). What am I getting wrong?
