Wonder if one of the techie types might be able to answer a question about the rectifier diodes in a MIG welder.
My welder has a centre tapped secondary main transformer and each end of the winding has a rectifier diode. The outputs are then joined together and supply the torch etc. The centre tap goes to the earth clamp via the choke. Since each diode is half wave rectifying it's phase of the supply from the transformer could someone tell me:-
1) Is each diode handling the full output voltage of the welder (I assume it is?)
2) Is each diode handling the full output current of the welder (I can't decide!)
I admit this is more out of interest than a need to know but it occurred to me that if the output rectifier should fail I'd like to upgrade with a couple of beefier components but am not sure what specs I should look out for. ie would a 140 amp welder need 140+ amp diodes and would they need to be at the highest output voltage the machine runs? I know it would be safest to assume the highest figures but cost of parts rises very fast with voltage and current so lower figures would mean cheaper parts!
Got my SIP 140 apart again to play with the wire feed- PWM speed controler parts have arrived so that will keep me busy for a while. Just had hernia op and too much time on my hands???
Cheers to all
Cheers to all
