Hi all,
I posted previously about a castomag 180 blowing the 13a plug fuse instantly when the trigger is pulled, well i have been working through the wiring and testing it with things disconnected when i noticed that when you pull the trigger and the relay is thrown you can see a flash inside one of the rectifier diodes.
As this is all new to me i wanted to check if there should be a flash in the diode or if it sounds like this is the culprit or would there be a flash with another fault?
