we have a Xmas tree with built in flashing led lights.
theres no switch to tone it down.
so I was wondering if a dimmer switch would fine?
if not is there any thing that would do the trick??
The led interior lights i have fitted in the disco, LR btw not club
dim in the same way as normal bulbs as the timer dims them out,
but they are 12v yours probable run off a switch mode PS that will work from 100 - 250, so maybe not. with a standard dimmer
but if they are DOL then maybe.
If SMPS you could try some resistors in the line to the tree or even a potentiometer.
tape em! to many and I aint wanna do dat!
heres the transformer details.
230/240volts 50hz
24v-500ma 12va.
thanks Alan but not a clue how to wire it up?
to tell you the truth I don't know if they are led but they do change colour as they flash on and of but its so quick you don't see them go of.
there is what appears two wires going into each bulbs.
in between the transformer and the lights there is a little box with diods/resisters or what ever you call them but no switch is in it.
if the lights didn't flash that would be better, my son said disconnect those ?? in the little box ,in other words just join the two wires.
but this will no doubt affect the colours and we don't want plain white light.
what do you recon??
