brightspark
- yarm stockton on tees
not cutting metal they aintHope someone tries them + how long they last in real use, still not convinced
In terms of physical integrity the steel cored diamond discs are far far safer than any carborundum based disc. I have seen them subjected to every kind of abuse and yet to see one break. The larger sawblades I've seen with 3" long cracks raidally around the periphery yet they still seem to always hold together.
But steel discs for a 9 inch cutting stone are more available/popular than composite ones.Not something I might entertain, 9" std discs are dangerous enough when they let go - no way am I going hard steel ones
and fibre ones are ok if used properly with a guard onNot something I might entertain, 9" std discs are dangerous enough when they let go - no way am I going hard steel ones
As I have had many of them break I just take the precautions. I know a fella who had a steel diamond disc break and it darn near killed him. Still works with them but spends a good while inspecting them now (other trash hawks swoop on the ones he chucks away). None the less I have to use them on stone at times but I heed his cautionI think you've got it the wrong way round, abrasive discs (particularly slitting) are as weak as and don't take much to break. I can't see the steel ones being dangerous in this way.
I use the steel diamond blades on stone stillBut steel discs for a 9 inch cutting stone are more available/popular than composite ones.
haven't tried them but talking to people who have most say they dont last the quarter of the cuts advertised
Wasn't there at the time but he was cutting and blade broke. Don't know why only found out when I teased him about his caution, his mate told me the why. I go through about one a year at most cutting stones in the 9" when required. Mostly they just burn out and stop cutting but I am cautious about the blade guard position knowing that it could always go wrong. Broke lots of hss circular saw blades cutting box and angle but not as fastIn 27 years of diamond cutting I've never heard of a diamond disc failing. I've seen one (3 foot diameter blade) bent 90 degrees when my mate Gary was cutting a service yard slab and nearly has a lorry reverse over him, it hit the road saw and pushed it over with the blade still in the floor but it still didn't break.
I'd love to hear the circumstances which nearly killed the guy you know Kent. The worst I've seen is a few lost segments, never an actual blade breaking and we owned the biggest diamond blade road saw in the UK.
