Guineafowl
- Nairn
New pump (https://www.advancedfactors.co.uk/qvb101350-defender-90-110-td5-power-steering-pump-40250-p.asp) and both pipes changed. Old one was leaking a bit.
Did the LR workshop manual bleed procedure (run up to op temp, open steering box bleed valve). Dexron III fluid used.
The new pump is making a moaning sound which varies with engine speed.
Went through fault diagnosis in the same manual:
1. Check pressure pipe isn’t vibrating against body
2. Bleed system (did it again).
3. Do figure-8 manoeuvres.
Also, no leaks. Is it time to return the pump? Oddly, the fault diagnosis never mentions a faulty pump as a source of moaning noise.
