Craig-SM
- Heckmondwike
Those are the onesAssuming these are the correct blades, 18 quid each on ebay, 28.80 if you buy two.
Thank you. i shall order some.Those are the ones
The Dremel is too delicate. I use these homemade small abrasive discs.I’ve used these to cut metal before but my favourite tool for cutting the head off a bolt if access is tight is my Dremmel with a mini cutting disk.
Nice. That pic is giving me flashbacks.Had a bash with the milwaukee torch blade this morning.
Chopping off my D3 rear upper suspension wishbone.
Worked ok. When i thought it was getting a bit blunt on the tip of the blade that was doing the work, i cut 2" off the end with a grinder. This worked well and gave me 3 good goes with the blade.
