Craig-SM
- Heckmondwike
You should see the Discovery 3 supplied with a tool, it's a total joke.
Fixed that for you.
Greta for jub clips in awkward places.I prefer my M12 ratchets for engine work, my M12 Short 1/4 drive gets used almost all the time now.
Nice for running fairing fasteners out as well.
Does anyone really want air tools these days. Not trying to start an argument, but I have the set of dewalt brushless from big to large impact. Never really needed the large impact even when changing truck wheels for the local farmers.
Vehicle workshops will never go air-less, so why not use the 'free' power rather than having to spend on spare & replacement batteries?
Obviously a different game if you work mobile or are starting out, but your first choice of battery power will tie you into that 'ecosystem' of battery/charger/tool combination whereas air allows you to choose & use from any manufacturer without having to replicate critical parts.
All my impact guns have a speed/torque adjustment, as do some of my air ratchets and feathering the air trigger is something you learn as an apprentice, right after the first time you slam your knuckles into something hard.The other issue with air guns/drills, is they are pretty much all or nothing power wise, battery you can slow to a crawl if need be.
Never had a good experience with air tools. I did buy into the air tools thing years ago but but just never liked dragging the airline around. I mainly work on classic cars and just do want them dragging floor grit across my paintwork. I used to use them at my Fathers heavy commercial garage and they were powerful but I suspect batteries have come a long way in 30 years. I think the other reason I don’t like air tools is my compressor cannot keep up running of a 13 amp single phase supply. I’m guessing at the end of the day we all have our own tool preferences and it’s what works best for you. I should also mention that a lot of people may only have experienced cheap air tools which are all useless in my experiencE.
That's why I like my electric guns so much. You can just leave it on full power, and control it easily with just the trigger, whereas air gun triggers are usually far harder to control precisely so you have to change the power dial.Speed adjustment on air guns is not like the trickle you can run a cordless down to with precise control, plus I have never seen anyone use an air gun on anything less than full power, the real skill is knowing when to let go of the trigger, something that not many can perfect.
I did not realise people still used air ratchets?
So you are saying hand on heart that you can throttle the air guns consistently, not just messing about but in use?Well I must be using them 'wrong' then, I can quite easily and subconciously control the speed of all my air tools - including ratchets. As I wrote previously, I don't see any benefit to me in changing them for electric versions, but if I was starting out now, I'd probably be buying a proportion of battery tools, not exclusively though.
Let’s just analyse your reply.
“dragging the airline around”. A matter of organisation?
“dragging floor grit across my paintwork” Not ever thought of an overhead supply?
”my compressor cannot keep up running of a 13 amp single phase supply.” Any compressor, up to 3 HP will run off a three pin plug. That includes all compressors of lower motor power. What size is yours? A decent quality 3HP compressor will produce about 10cfm - enough for most air tools. What are you using, or how many are you using at the same time?
”a lot of people may only have experienced cheap air tools which are all useless in my experiencE.” Dead right there. ‘Buy cheap, buy twice’ is the age old saying.
Only 110V portable/hand tooling is permissible in places of work, these days (unless a single person as sole trader?), so twice the current and heavier trailing leads or more localised socket outlets required.
Batteries get depleted, so chargers are required and at least two batteries if used continuously. Batteries have a limited life - particularly if operated/charged when hot.
Most battery tools, while adequate, have a limited power output - mains or air tools can be much higher powered.
Spare parts for cheap tools is often a problem - they are not supported.
Battery powered tools may be great for on-site work, but not so great for well organised indoor premises. Lighting is the obvious analogy - virtually all premises use mains powered lighting, not portable battery options.
It is generally only small power tools that are bought as the battery option - all high power tools are either air or grid electric (battery storage as an alternative, for some grid power, is becoming ever more popular.
Hand-held battery tools are generally less economic than “direct from the mains’ power - less long-lived, require extra energy transfer (charging from the mains) and battery life. Their only positive is they are more portable. Occasional use is OK, but continuous use is less efficient/economic.
Battery operated power tools for on-site use is likely a much cheaper (operationally) than running a fossil powered generator for equivalent mains voltage tools.
As I see it, it all comes down to cost and/or convenience. ‘Convenience’ seems to be the popular word these days, convenience stores, convenience foods, convenience everything. Go figure.
