Munkul
Jack of some trades, Master of none
- Cumbria
so... I have a 40V DC motor on this welding positioner I've just bought. Originally it was powered by an automatic welding power source with an encoder for feedback. I just want to power it and make it variable speed.
It is a Dunkermotoren GR53x57 nominally rated at 1.9A and fault current at 20A.
I already have a suitable PWM speed controller, tried and tested on a 24v motor, it's rated up to 60v and 10a. I'll protect the motor with a 2 amp fuse, if I can't limit it via the supply.
So I need a power supply.
Finding a switched mode or linear power supply rated at 40V for under £100 seems to be a fruitless task. All I can find are 36V and 48V supplies.
So... I'm wondering, could I just feed it 36v and accept the small increase in working current? Or is this a silly idea? I certainly don't want to burn it out, it's an expensive German motor. I also don't want to under-power the positioner.
Similarly, 48v sounds like a bad idea too.... unless I can get an adjustable PSU and manage to turn it down far enough... OR is it? given that it's going through a PWM controller...
Lastly, I could just buy a lab adjustable power supply and run it off that, but it's not cheap and it seems like a waste, when I just want to build a neat little enclosure with the supply and controller, 240v in, and a socket/plug for a foot switch.
Any suggestions?
Any suggestions?
