indy4x
- Pontypool, South Wales. UK
Used to make body lift kits out of UHMPE. 60mm dis bar, cut to length with a bandsaw, face off to size in the lathe and then 10.5mm hole through the middle
Bandsaw was a horizontal metal jobbie, used HSS tooling in the lathe and normal HSS drill bit. Just make sure your tooling and drill bit is sharp, keep your speed down to limirt the chance of the plastic melting.
